L-86 or 6.2L Emblems for our trucks
GTD
Would anyone else but me wish there was a designation showing what's under the hoods on the 6.2 powered trucks?
  • Replies 46
I did when I had my 2011 Silverado 6.2L. I found some on EBay, and added one to the tailgate where the LT emblem was.
Sent from my Droid Ultra
You don't put Ford badges on GM trucks. That's just the rules. :throwup: The Ford guys would laugh at you.
There's all kinds of aftermarket Vette and Camaro 6.2 badges. Probably some factory 6.2 stuff as well.
L86 would be weird.. 95% of the people who see it would have absolutely no idea what that is
Shades of late 70's Corvette those with the higher output L-82 high ouput engine carried this emblem on its hood. Would be a throw back, who cares if only 5% knew what L-86 meant, that means their up on there GM history. Yeah maybe 6.2L would be OK but I like the L-86 better--my opinion. Thanks for inputs.
While you're at it, why don't you add some stick on Buick vents to the fenders? Your bubbafied embellishments are going to look real pro...
And if he wants to do that who cares? Your not paying his truck loan so he can do what he wishes
Ryan
specfaculous you should keep your own stupid ideas to yourself, who would put the Buick vents as you call them on a Silverado or Sierra?
6.2L fo sho. No raptor badges
That looks really clean, nice
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 445 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
