Hot rear brakes
So I just replaced my rear brakes because they were squealing bad and then I drove the truck today and my rear breaks were dragging hard. I could feel it and so i pulled over and checked to see if I could see if anything was wrong and my rear brakes and my rims were extremely hot. So I re-bled the brakes, no air in the system what could be the culprit? I am drawing a massive blank here. Please someone help ASAP thank you for your time.
Sticking calipers?
+1
Caliper slides must be clean and lubed with the correct lube
It is definitely the calipers both of my rear ones were hung up. I got the replacement parts my advise go to advanced auto auto zone only has the caliper itself as where advanced has the caliper and the bracket for the same price.
Sent from my SPH-L720T using Tapatalk
I will order n calipers or parts, but I'm located overseas in Norway so I don't have to many options. I will call and see if I get rebuild set, calipers or complete loaded calipers.
Be sure and inspect those rear e-brake linings as well. GM had fits with that set-up so they changed back to rear drums in 2005.
It's not my parking break because once I replaced one side the heat went away. So I got all the parts to completely redo everything.
I found the issue with mine. The pads was to thick and I grinded them With 100 grit paper on a steel plate down to 14,5mm approx 1 mm. One of the sliding bolts also had rust in the bottom of hole so it could not fully return. I used a 5/18" / 8mm drill bit and cleaned up and lubricated all with copa slip/ copper paste.
So now I have rebuilt calipers and cold brakes.
Regards from Norway :-)
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   3 Members, 0 Anonymous, 597 Guests (See full list)
