Smooth Flares - Color Match or Black?
I'm fitting up the Bushwacker smooth "Extend-A-Fender" flares. I put one side on and took some pix. Trying to decide if I want to have them painted to match or leave them black.
Bushwacker's picture from their website.
Both ways look good. Black will look good with less care, and rock chips won't show.
That was my vote. Either way would work. The black goes well since inside the wheel wells were black.
Ryan
I would go color match but request flex additive if you paint them that will help a little with rock chips.
You MUST use the flex additive to paint them, or the paint will crack and flake off.
My Wife has voted for color matching.
That's the only vote that counts hope you didn't want black
Ryan
Color match all the way!
The decision was made after this post.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 870 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
