New here with a few questions
Well my local dealer doesn't have a 6.2 in stock to try so I might have to go out of town to try one. I understand the torque management will be on both to help save fuel but I want some bottom end power.
Btw, the truck I test drove had the 3.42 axle ratio
The only changes confirmed for 2015 are upgraded My Link with AT&T 4G connectivity. Not worth the wait in my opinion. Everything else is speculation. 8 speed for 2015 would be a great reason to buy a 2014, but there's been no word from GM. Even if it was available, it would go to Escalade and Denalis first and be an option on other trims. Additionally, GM has announced that they've partnered with Ford on a new 10 speed for the trucks due out in 2016/17, so I don't see why they'd go to the expense of offering an 8 speed for 1 or 2 years. All the other problems are mostly worked out by now. GM has been pumping out >60k of these trucks a month. Very few have problems. And FYI, won is full of crap. Ignore everything he says. He just likes to bash the new trucks and GM.
Wait for 2015. Big changes are coming but it might not happen right out of the gate. The 5.3L felt slow because it is. Get a 6.2L & don't look back, unless you want to see 5.3L powered trucks in the RVM.
Still talking out your arse, I see!
Exactly!
My advise is walk your salesman to death. Drive as many as you feel you need to to find the perfect truck. Don't overlook the little things, like tire p.s.i. Mine was over 40 p.s.i. when I checked it the next day. Makes a big difference on how these trucks drive. You can check it via the controls on the steering wheel. If you choose the 5.3, go with at least 3.42 gears. Just don't assume that every truck is the same . Some tick like time bombs,some do not.It is only the direct injection.But it can drive you nuts while sitting at the drive thru window. Some are very noticeable when switching from V8 to V4, again some are not. Happy shopping and good luck. Post pics when you buy.
If I can find the exact truck I want in a 2014, I'm sure ill buy it, other than that I might wait and just order a 2015 even though it wouldn't be as cheap
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
