Brakes problem on 2001 Silverado
...The lower rotational mass/unsprung weight will help your acceleration a bit too.
Think gyroscope. Less mass is easier to spin up. The drilled/slotted rotors are significantly lighter. It's a small advantage, but it's an advantage.
Not following on the acceration part. Or are you meaning just because 10-20 lbs less weight there is less total weight on the vehicle?
Remember this is coming from a guy that has 600 lbs of gear/tools in the bed of the truck on a typical day and some days 3/4 ton in back with materials. :D
...The drilled/slotted rotors are significantly lighter....
+/- 1/4 lb weight reduction will help with combined rotor, wheel, tire weight of (I'm guessing here) > 65 lbs?
Sorry, but that borders on the mystical.
Why hasn't Formula 1 adopted them?
Cheers from an old churlish cynic.
Check out a book on physics. A smaller mass will spin up quicker than a larger one, given all other variables are the same.
It might not be much, bit it's measurable.
As far as formula 1 goes, I don't know their rules, nor do I care. I'm nor a race car driver. I do, however have a good knowledge of physics.
Arthur C. Clarke said something that applies to this conversation beautifully:
" Any sufficiently advanced technology is indistinguishable from magic. "
I threw out the ash tray. Acceleration has improved. :driving:
Lol :becauseracetruck:
These are trucks, not sports cars. Save that drilled/slotted bs for other applications, especially since we're body on frame and on leaf springs! There are so many other things to improve like better lines, fluid, shocks, bushings, etc.
