Update: Truck has been at dealership since last Monday trying to get the service 4wd message to stay off. Service advisor called and said they ordered new sensors and put them on yesterday and truck would be ready today. I called to see when I could pick it up, and advisor said tech went for a drive this morning and put truck into 4wd and it would not come back out, so they are gonna try different programs to try and see if they can get the truck back into 4wd. When do you guys say enough is enough, they've had my truck 3 desperate times, and over 20 days, and I'm not sure when I will get it back? I fish bass tournaments and have lost entry fee's cause I don't have a truck to pull my boat with, can't load up my atv and go ride. Just frustrating
Check your state's lemon laws, if this is the 3rd attempted fix for the same problem you may be able to get the vehilce "lemoned" out so you can move on and get a vehicle that works for you.
Update: Truck has been at dealership since last Monday trying to get the service 4wd message to stay off. When do you guys say enough is enough, they've had my truck 3 desperate times, and over 20 days.Just frustrating
Thanks for the updates. The more I hear about this, the longer I'm going to wait before ever going back to the dealer for a recall. I still get the "Service 4wd message" every day or so but the truck works fine in 4 wd so I merely dismiss the message and carry on. I'm just too afraid to bring it back to the dealers and have them do the same thing to my truck that they have done to yours. It only has 1200 miles on it so imo there is no reason to start ripping everything under the sun apart trying to fix a problem that did not exist until I brought it in for the recall the first time.
Don't understand why dealers just don't try the recall updated tune again. It works for some.,
Because they are not going to get reimbursed by GM when they have to write up a new work order to do it again. They only get reimbursed to perform the recall once.
Edit: I know it's a stupid excuse but unfortunately it's the truth for the lower volume dealerships
Edited by 14LTZZ71
That's not true. They can just run it as a Regular transaction, and not a recall. They will still get paid .3 for reprogramming the transfer case control module.
whats not true? and what will be the reason for the reprogram, "you screwed up and didnt do it right the first time"
Edit: I am by no means saying that they shouldn't reprogram it and do it correctly the 2nd time.
Once you close the ticket saying that the recall has been performed you can't go back and say your performing the recall again and expect to get reimbursed for it.
I guess you could manipulate the system and write it up the ticket as a regular transaction saying that you had to reprogram for a different reason (but just don't include anything about the incompetence on the part of your service techs to perform it correctly and then check it before allowing the vehicle to be picked up by the owner), because that part GM won't reimburse you for.......
Edited by 14LTZZ71
What I'm saying is, if the recall has been performed, and people are getting service 4wd messages, then they reprogram the transfer case control module (pretty much same this as the recall) and it is submitted as a regular transaction. So to say, they won't do it again because they won't get paid for it is false.
Edit to add: There is currently as Preliminary information bulletin describing multiple service 4WD messages, and engineering is currently looking for a solution. Until then, dealers are to perform the TCCM reprogram.
Edited by Libertas
From my experience, when they did mine the first time it was done incorrectly and I got the service 4WD message, so when they did it again correctly the 2nd time I have never got this message again.
So you are saying the fix is to keep reprogramming the transfer until it is done correctly and the 4WD message no longer appears, and just keep charging it to a regular transaction so you get reimbursed for it. Wow, ok then.
Edited by 14LTZZ71
My truck is at the dealership today with this exact problem. I just had the transfer case recall done about 2 weeks ago and this message started right after that.
Guess I will be surprised as to what comes out of it, and what they find is wrong with it.
*Update* They called late and said they were replacing a sensor on the transmission. Part is supposed to be in today.
I am curious which part it is, I guess I will check the invoice.
Mines still at the dealership, the sensors they put on last week didn't fix it. They ordered some new parts to put on and see if that will fix it. Today is day 25 they have had my truck trying to fix not shifting into 4wd and 4wd service messages. I'll just be glad when I can get my truck back.
One would think that GM would have caught on by now. It seems that after the recall was performed the false "Service 4wd" messages began appearing. My dealer wants me to bring mine back in because they say that certain codes will have been set and they will know where to go from there.
There is just no way that I'm going to let them touch mine because besides the spurious message, the truck runs fine and I can shift into 4wd without a problem.
If I let them screw around with it who knows what else they will do.
**update again** The dealer is telling me that the problem stems from my footwell lights I installed and the jumper wire I used to hook into the domelights is causing the issue. Basically charging me $200 for labor since "I caused the problem"
Does this sound legit?? The dome light and xfer case on the same circuit?
Doesn't sound logical but then again, nothing surprises me anymore with these trucks.
Update............
Brought mine back last week and they agreed to reflash the software before taking anything apart.
Well, things went well for a week, no more "service 4wd message" but then yesterday I did get another one. The dealer has been more than fair, the truck runs well, no problems with the 4wd so I'll just wait until my next service call or oil change before bringing it back to further explore the message and codes.
Unless of course, if I really do encounter a 4wd problem.
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,533 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
