Towandrace25 Posted July 6, 2014 Posted July 6, 2014 So I just picked up a 2013 2500 Suburban. The tire pressures were off on the DIC and when cycling through the options to relearn tire positions, it is not there. Very strange...ideas? The DIC is showing tire pressures and while wrong by verifying the pressures with a gauge, it still is showing a reading. But I cannot relearn with no option to do so! Any ideas??
Towandrace25 Posted July 6, 2014 Author Posted July 6, 2014 Can you no longer learn via the old method through the DIC, bleeding tires in order, etc?
WireBender Posted July 6, 2014 Posted July 6, 2014 You have to use a TPMS reset tool. You can have this done at the dealer or a tire shop (takes five minutes). Or you can purchase one to use yourself. Kent-Moore EL-50448 TPMS Tire Pressure Monitor Sensor Activation ToolI usually swing by the dealership after I rotate my tires and have it done.
montyss Posted July 6, 2014 Posted July 6, 2014 without the relearn option in the dic you can put the ignition key to acc truck in park ,then on the key fob press and hold the lock and unlock at the same time the horn will beep and you can start the relearn process
Duelin Posted July 6, 2014 Posted July 6, 2014 Changes to the Service Procedure GM Product Engineering has determined that in some instances the manual re-learnprocedure can cause the TPM system to pick up stray sensor signals from nearby vehicleswhich can result in Diagnostic Trouble Codes being stored and parts being unnecessarilyreplaced. To address this concern GM Product Engineering will be disabling the TPMmanual re-learn capability from the vehicle software starting January 2011.A Special Service Tool is needed to perform TPMS Re-LearnDue to the changes in vehicle software, a Special Service Tool is required to perform theTPMS Re-learn procedure.If your dealership currently has the EL-46079 (J-46079), you can continue to use thistester for the Re-Learn procedure.If your dealership does Not Have a special service tool to perform the re-learn procedure,it is important that you purchase the new lower cost tool (EL-50448) that will perform theRe-Learn function. The tool needs to be in your dealership in time to service TPMequipped vehicles manufactured after January 2011.TPM equipped vehicles manufactured before January 2011 can continue to use theSpecial Service Tools (EL-46079 or EL-50448) or the manual procedure for TPM Re-Learn.Note: the diagnostic functions that are currently included in the EL-46079 will be built into Scan Tool Diagnostics. The new EL-50448 does not contain the diagnostic featuresthat are included in the EL-46079.
Doug_Scott Posted July 6, 2014 Posted July 6, 2014 What does it say in the owners manual? I know in the 2010-2012 GMC Sierra manual for sure it has instructions like montyss has listed. I have a friend that bought a 2012 Sierra SLT and his son got a 2012 Sierra SLE, and both vehicles still have the manual way to set TPMS. With TPMS being a federally mandated item, there must be a free way to reconfigure after something simple like tire rotation. Do not really see how the system could be picking up another vehicles sensors by mistake. The other vehicle would have to be adjusting the air pressures at the exact same time your vehicle is trying to learn yours. If that was the case, your own vehicle would cause this issue since there are 3 other sensors well within range. I know from my own experiences in 2010 before getting the tool, mine were set to 4 different sensors when change over to winter tires and wheels took place. At that time, there were 16 different sensors surrounding my truck while it relearned the sensors manually. Never had any issue of confusion. I split the cost of the tool with a friend who also happens to be the guy that rotates tires on my truck(back injury, can no longer do the simpler things). Very handy tool to have. I can't see the dealer doing this for free for everyone that comes in either. Having worked flat rate for many years, being asked to go out to the parking lot to perform a "couple of minutes" job for nothing gets irritating pretty quickly. The dealership also would not like having to pay technician .1 or .2 and not be able to recoup from customer. I know this is getting off topic real fast, but, it brings to mind something that most customers never will understand, there is no such thing as a job that only takes 5 minutes to do. Unless the vehicle is delivered to your work stall(or bay), it takes a minimum of .2 to get the car to your bay or stall, and then returned to parking lot. The actual work is done in between those two actions, and are not included in the .2 min charge. edit was to update content to address post before mine.
Duelin Posted July 6, 2014 Posted July 6, 2014 This was taken from a 2012 Owners Manual. Pages 10-67 &10-68 The TPMS sensor matching process is: 1. Set the parking brake.2. Turn the ignition to ON/RUN withthe engine off.3. Press the Remote KeylessEntry (RKE) transmitter's LOCKand UNLOCK buttons at thesame time for approximatelyfive seconds. The horn soundstwice to signal the receiver isin relearn mode and TIRELEARNING ACTIVE messagedisplays on the DIC screen.If the vehicle does not haveRKE, press the DriverInformation Center (DIC) vehicleinformation button until thePRESSVTO RELEARN TIREPOSITIONS message displays.The horn sounds twice to signalthe receiver is in relearn modeand TIRE LEARNING ACTIVEmessage displays on the DICscreen.If the vehicle does not have RKEor DIC buttons, press the tripodometer reset stem located onthe instrument panel cluster untilthe PRESSVTO RELEARNTIRE POSITIONS messagedisplays. The horn sounds twiceto signal the receiver is inrelearn mode and TIRELEARNING ACTIVE messagedisplays on the DIC screen.4. Start with the driver sidefront tire.5. Place the relearn tool againstthe tire sidewall, near the valvestem. Then press the button toactivate the TPMS sensor.A horn chirp confirms that thesensor identification code hasbeen matched to this tire andwheel position.6. Proceed to the passenger sidefront tire, and repeat theprocedure in Step 5.7. Proceed to the passenger siderear tire, and repeat theprocedure in Step 5.8. Proceed to the driver side reartire, and repeat the procedurein Step 5. The horn soundstwo times to indicate the sensoridentification code has beenmatched to the driver side reartire, and the TPMS sensormatching process is no longeractive. The TIRE LEARNINGACTIVE message on the DICdisplay screen goes off.9. Turn the ignition switch toLOCK/OFF.10. Set all four tires to therecommended air pressurelevel as indicated on the Tireand Loading Information label.
WireBender Posted July 6, 2014 Posted July 6, 2014 All the above information is true. Read the Changes to the Service Procedure posted by Duelin. You can no longer reset the TPMS without the relearn tool. But you can go to the dealer and have them do it for you. I don't know about where you live but all I have to do is drive into the service department and they keep the tool handy. It does only take five minutes and it is free. My vehicle does not have to go into a service bay and a technician is not called. Maybe I am lucky.
Towandrace25 Posted July 7, 2014 Author Posted July 7, 2014 Thanks all. Yes, I ended up going to a tire shop and they let me use their TPMS tool to complete the reset, which worked perfectly. I guess I understand why GM did this, I suppose, but Merchants Tire wanted $55!! I can only imagine how much the dealer would have wanted. Thanks again everyone!
Duelin Posted July 7, 2014 Posted July 7, 2014 Thanks all. Yes, I ended up going to a tire shop and they let me use their TPMS tool to complete the reset, which worked perfectly. I guess I understand why GM did this, I suppose, but Merchants Tire wanted $55!! I can only imagine how much the dealer would have wanted. Thanks again everyone! For another $15 you could buy the Relearn Tool.
Towandrace25 Posted July 7, 2014 Author Posted July 7, 2014 That's what I told them just before I walked out the door! Haha.
Doug_Scott Posted July 7, 2014 Posted July 7, 2014 This was taken from a 2012 Owners Manual. Pages 10-67 &10-68 The TPMS sensor matching process is: Both of the 2012 Sierras my friend has (his and his son's) were both purchased in late Aug-early Sept 2011. And they are in Canada. Perhaps the change was done later in 2011 in Canada. Don't know, both owners manual have the old way of syncing wheels and tires. Duelin, are you saying the relearn tool from GM $15 dollars, or $70? There are lots on ebay for less than $70. Does the GM relearn tool work on all brands of cars/trucks?
Duelin Posted July 7, 2014 Posted July 7, 2014 My post was referring to around the $70 figure. I don't know if they work on other brands or not. All I own is GM.
reef21 Posted November 30, 2015 Posted November 30, 2015 My 2013 Sierra does not show the "Relearn Tire Positions" option on the DIC, after having applied parking brake and turning ignition to ON. I have an aftermarket remote start so I have no factory fob. When I push the Lock and Unlock buttons on the aftermarket fob, nothing happens. Further, the truck has no trip meter reset stem, therefore I have zero options available (from the Manual) for putting the truck into Relearn mode. Has anybody been in/ heard of this problem before? Garages here charge a half hour labour for this and I do not want to have to order the Autel ts601 if there is another method for initiating the TPMS Relearn Mode.
