I think the Z71 has different shocks and struts as well as different tires. A lot of difference in setup with all these trucks. The trucks are solid in the sense of Frame and body and very good crash tests.. A recent software update corrected the feeling that of a 5 speed stick matted to a v8 engine running on 4 cylinders in 4th gear doing 32 miles an hour with slight acceleration... Yes. A lot of inwanted vibration. O guess someone new to programming transmissions is about the equivalent as someone new to driving a stick.. Glad it has been improved!!
some things I think these trucks may all still have in common are:
- the tin can likeness.. Gravel on the rockers, wheel wells and under body resonate through the cabin like you're in a old cargo van. A little Shultz would have went a long way here.
- carpeting is piecemeal. If you peak back the carpet behind the rear seat you will see the studs sticking up like an inch over the nuts. lol
-the back up camera looks worse than my wife's 2004 Lexus gx470! As well as awful radio reception'
- the seat cushions are great until they start to wear out and wear out quickly they do! When you feel that alert probe in your right thigh. My dealers fix was to replace the seat cusion and leave the probe dangling on under the seat. And while they were at they have me the truck back with the lane departure warning turned off.. Well trained guys at jersey city Chevrolet. Even had a service excellence plaque on the wall.lol these guys are worse than shade tree used car people. I believe they'll take engine bulb out of your dash.. Never going there again!!!
In the meantime I'm shopping for struts and wheels and tires and a few cans of Shultz. Never thought in my life that would buy an $80,000.00 dollar truck that needs to modified just for every day 25-35 mph street use...(granted the streets of New York are a lot like off roading) Probably should have waited for the Z71 to come out.
Your in ny right. What dealer have you been dealing with for your issues? Edited by Lift
So, I picked my my '16 Yukon Denali on Friday. It seemed smoother than the two I test drove, yet there's still a very slight but noticeable vibration (to me, not my wife - she just likes the roominess of her co-pilots spot!)
It's very smooth up to about 10 mph, then it's like flipping a switch with what feels like a minor drive train feedback. It does not feel like a tire balance issue since it does not vary much by speed... but then again, who am I to say!
There's no issues at (highway) speed in terms of the "back window open" effect, so that's a good thing!
I went ahead and got it, as it's got too much else to offer for this minor issue to derail. Sure, I'd prefer it to be smooth throughout the range of speeds, but...
Some other observations:
> I really do like the Adaptive Cruise Control, though I'm still adapting ( ! ) to it. :)
> Heads Up Display - very nice OTHER THAN when using it on a sunny day AND concurrently wearing polarized sunglasses (Rx). It's almost invisible !!! When clouds roll over, it's definitely easier to see. At night, I assume it's a non-issue (since no polarized optics at that point!) but I have yet to drive it at night!! Two days after getting this vehicle we headed down to Ft. Lauderdale to jump on the Allure of the Seas... in Haiti now! :)
Manfredi, I Reyes dealing with once and they wanted to charge me to troubleshoot the problem. I said thanks but no thanks. Oil change tire rotation and good day! They gave the car back with greasy paper floor protectors and oily footprints on the running boards.. A closer look at the wheel locks reveal a socket and a hammer was used to take the wheel locks off instead of asking for the me for the wheel lock key.
Potamkin is better but they're all the way out in Harlem.
Chevrolet of Jersey city is the last place I went and trust this place at all.. I have one last visit scheduled there after I gave them a bad review on the GM dealer service review survey a GM representive called and asked if she could help get this warranty work done. I replied just let them do the struts.
I had some people in the car with me when j was driving through Brooklyn to get on the Manhattan bridge ask me if My tire blew out!!! lol I replied no and blamed the mayor for not fixing the roads.
If you're happy with it, that's all that matters, but if you follow thru the thread history, the vibration (vs the "open window effect") is the much much harder problem to fix, IIRC only seen 1 person get it fixed and went thru 2-3 major rear end parts being replaced (struts, drive shaft, etc)
Edited by boazEarl8
Bought a 2015 Tahoe in August. From August to present day June 1st, 2016, my Tahoe has been in the shop reference a cabin pressure issue a total of five times. They have had my Tahoe approximately 2 months total out of the 9 months that I've owned it. The cabin pressure issue occurs upon reaching 40 miles per hour. It is very annoying. My wife in the last 6 months has been getting migraine headaches, I think I now know why she gets these migraines. The Service Department has changed the lining in the roof, balanced the tires, but nothing seems to work. Got a phone message today that the problem is 90 percent fixed but the cabin pressure issue is still there. Called the 1-800-222-1020 number and made a claim. The person handling my claim won't answer my calls or return messages left. I guess I'll continue driving the rental until the problem is 100 percent fixed. And to tops things the A/C compressor went while on vacation. Try driving around the Las Vegas area on a Holiday weekend and all Chevy Dearlerships passing the buck because no mechanic is available. Go figure. Very disgusted with this brand new Tahoe with 11000 miles.
Yep - it just came down to how much I like the vehicle vs. what I think I can cope with. What I'm not up to is countless days of having my vehicle in the shop while they experiment with what might work. If a predictable solution comes to pass, then I'll take it in, otherwise I'll just use up my 39 months of time and trade it in on a (hopefully) problem free, or reduced, 2020 model !!
Hey, when is the next (projected) model update coming along for this platform??
Hey Ace1424,
I'm sorry to hear you're experiencing a concern with the cabin pressure in your Tahoe and understand how multiple trips to the dealership may be frustrating. Can you please private message me with your VIN, mileage, contact information, and the dealership you have been working with in order for me to look into this further?
Thank you,
Anthony Z.
GM Customer Care
I bought my vehicle remotely, I live in Texas and the Tahoe was in Ohio, and the dealer did not disclose the wind buffeting, vibration, etc. Is there any recourse I can take for this? I am extremely dissatisfied that they were not upfront about these issues.
Ok you folks, I need your help again. I ordered a new 2016 Yukon XL back in November 2015. The day before I was to pick it up I ran across this forum. I walked away from that suv. I still miss it. Did not want to take the chance of getting a bad one, if anyone will get a bad one it will be me. Has anything changed. I drove thru the GMC lot today and they have two the same way I ordered mine. Now on some older models I think at least one qualifies for a $3500 rebate. Do they still suck? Do you all need to talk me out of buying it? What to do. thanks. john
Man, this is the best truck I have ever owned, it's everything and a bag of chips. I have not experienced any of these issues and I am probably the longest owner on this site with the same truck. I can go on for days, but I need to answer your question below...
Are you crazy (nothing personal, just had to say that). Everything is great on my truck, but if GM offered an even trade with a newer truck, I would tell them they were smoking crack. I believe problem trucks are a small percentage, but it would suck if I was in that percentage. Go ahead and get a new truck, but Eastwood said it best, you feelin' lucky.
Edited by The Zip
Mine is a 2016 Suburban special order with 18" wheels built 10/31/2015. Great car no issues.
Dealers are rarely upfront, but you could talk to the GM or sales manager who sold it to you and see what they are willing to do, be prepared for nothing
Other recourse would be start keeping service notes and attempt to have your issues repaired and see if you trigger the lemon law
Same advice as we gave then
Test drive it first and see what issues, if any, are present
Keep test driving until you find a good one
Any vibrations stay far away
Hey Ace1424,
Thank you,
Anthony Z.
GM Customer Care
These questions are directed to Anthony Z. or any other GM Customer Care person.
What if anything has GM done to try to fix this issue. If you don't know find out and let us know.
Last I heard they were going to try a different exhaust.
Will the plant shut down for model change over soon even thou the style will likely not change. Will it be to make unseen changes such as add more roof bows, thicker steel or anything to solve the problems all these people have.
Please tell us what has been done and what date they started, also what is being planned for the future and those dates.
Let me know soon, as their is a nice rebate on them now, only if the issues have been quietly resolved, but if the 2017 will have updates I would rather wait and pay more knowing the issues will be resolved. If nothing has or will change then I will go a different direction. I can't wait any longer. then this fall.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 482 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
