1500 adding factory trans temp gauge
Has anyone added the Trans Temp Gauge to thier silverado??
I got a 1500 extended cab 5.3 auto
I think trans temp gauges should be standard on trucks!!! :cheers:
You have to change out the whole guage cluster.  Take a look at JP customs over on the left.  You could always mount an auxillary one, but the complete cluster would be the way to go. :cheers:
I did this with my 2001 Silverado 1500.  The new instrument cluster you need to retain the stock look it the cluster from a 2500 series Silverado.  It looks identical to the one you have now except the blank circle under the little info screen is a trans. temp guage.
All you do is remove the dash bezel, pull the old cluster, plug in the new one and the truck's computer calibrates the new cluster for you.  The only downside is that the odometer and engine hours are reset to zero (if you consider that a downside).  It took maybe 15 minutes to swap them out.
The GM part # for the 2500 cluster is # 15059383.  I ordered it at gmpartsdirect.com for about $165.
Yes, sending wire is already there.  I changed mine out in the parking lot of speedo repair shop where I bought my Denali cluster.  I went to the counter and told them I had a Denali cluster there waiting.  Handed them my old cluster and about 15 minutes later, I put the new cluster in the truck.  The display read the exact odometer and hours as I had on the old one.  Drove off, no problem since.  Installed July 2002.
The Denali cluster has 120MPH speedometer and the GMC "silver-TECH" look, blue back lighting.
The Escalade cluster has 120MPH speedometer, retrolook numbers and chrome trim rings around each guage, I think it has orange/red back lighting (other please chime in).
120MPH speedometer is fully operational, however to get the truck move that fast, you'll have to have ECM's speed limiter changed to 120+.
Tucson_02 Silverado is correct.  The new cluster is "Plug and Play".
You'll either need to have a speedo shop update the new cluster with your current milage, or you can put a sticker in the door jamb to indicate the milage is not correct.  That will save you from any liabillities when you sell or trade the truck.  I don't know about the laws in all the states, but the DMV here has records of the milage of your vehicle from everytime you do your registration and state inspection.
The changeout is simple.  The bezel around the dash just pops off.  I think there are four 7mm or 10mm bolts that you can remove with a nut driver, and then the whole cluster will be out in your lap.  Unplug the harness and plug it into the new cluster and bolt it back in...
Where is the best place to get a Denali cluster?
How much are they?
Seems that would be the one i want
I like the look of the stock cluster
I just want the trans temp
i thought that the cluster retained the mileage and hour info in the chip that is in it------at least that is what i'm told??????
If you like the look of stock you can always just get a 3/4 ton cluster that has the trans. temp gauge in it.  You will still need to do the milage swap though.   :cheers:
Tucson_02Silverado- If you don't mine my asking, how much did the mileage transfer cost you. After the mileage swap, did the original cluster retain the same miles as well?
The cluster will retain the milage info whether it is connected or not.
I remember a guy on here about a year ago that bought a used HD cluster (EBAY maybe??? ).  It had a few more miles on it than his stock one did.  He just drove the truck until he was close on miles, and then made the swap.
    • Done. I'll have more productive conversations with a hickory stump. Carry on! Keep the blindfolds on TIGHT!
    • This again?   https://www.reuters.com/fact-check/us-capitol-attack-rioters-had-weapons-including-firearms-2025-01-16/   Think Reuters is biased?  Check their rating https://mediabiasfactcheck.com/reuters/
    • I found an odor eliminator spray that neutralizes unwanted smells pretty well. Using it with the car's AC running helps to distribute it evenly around the cabin.
    • WTI futures / speculation is just that. WTI futures <> current 4-7% inflation and national average gas price over $4.00/gallon.   The spot price, at delivery, is currently $87-$95/barrel which is why gas prices remain high.   Edit: oH mY gOd mEnTaL BrEaKdoWn In tHE pOsT aBOve mInE. TrUmpErS goNnA tRumP
    • He does, actually. In another unrelated video he mentions the president called him in the middle of the night to relay some information on a cause (religious based) that he's invested in. Glenn expressed concern that another leftist administration could wield too much power with some procedure the Pentagon was using, classifying certain religions a certain way. Being that he is LDS (Latter Day Saints), he gets hate all the time from ALL over the political spectrum, so he's invested in this. Trump called him back at 5AM to tell him he had made some changes to that classification.   So, yes, they are and have been in contact regularly since the start of the administration. Glenn, of course, always asks his permission before discussing anything on the air.   I already spent an hour or more just searching for these videos. I may have my numbers wrong - I'm not a numbers guy. It may have been a MILLION barrels, not 1.5. The point is, our President, by his actions, gives a crap about America, and US - this is completely OPPOSITE the actions of the prior administration who projected hatred for anyone who wasn't following the left's edicts in lock-step.   Remember, they called January 6th an "Insurrection", when there were ZERO weapons among the crowd, undercover FBI agents agitating the crowd, along with paid leftists acting as aggressors, egging the crowd on in an attempt to whip everyone into a frenzy. It's all been proven.  Pelosi refused Trumps request for more National Guard troops. This smells 100% like an inside job for those with critical thinking skills. Only a handful of guys in the crowd got wrapped up in that, thankfully, but EVERYONE was searched out based on cell phone data, and charges were brought against many. And 6 or so people were locked up and left in solitary confinement for YEARS with ZERO due process!! If you give the slightest crap about our Nation, REGARDLESS of your political leanings, this should frighten you to your core. This is what men suffered, bled, fought, and died against 250 years ago!   This has gone FAR BEYOND left vs. right. This is a  threat to America, and our way of life. This is PRECISELY why Trump, a BILLIONAIRE who could have chosen to take Melania and sit on some tropical island that he could afford to buy himself and RELAX, instead chose to run for office, get hate from literally every corner of the media, get ATTEMPTS on his LIFE constantly, and begin to repair some of the severe damage that's been done to this Great Nation.   I don't know why I bother wasting my precious time here. Everyone has their minds made up. They won't realize we all were correct until it's too late ... after they elect another tyrant that hates America to office (Obama), or another puppet whose administration is secretly running the show behind the scenes (Biden).
