Power Sockets in Bed
I'm going to install 12v power accessory sockets in the bed of my truck for charging dog collars, cameras, running a . I did this on my 08. But I'm looking for better sockets than I used last time. They were cheap plastic Chinese made. Some good weather resistant sockets are what I'm looking for.
Any help would be appreciated.
The first socket is what I had in my last truck. Kind of cheesy. Looking for a real high quality socket.
I recommend looking at motorcycle power sockets. They are 12v (various socket types), designed for wet conditions and nice ones are available. One example is http://www.powerlet.com, but worth checking some of the motorcycle related online parts web sites for other brands.
Ive been planning to do this mod as well... really want a 110 back there too but im no electrician so ive been holding off
I really dont know that either... I have a food saver I want to run off of it for sure to put game in after a hunt. Other than that I dont know.
One options is to get an UPS and charge before the trip (or stops) for 110v power. For example: http://www.amazon.com/CyberPower-CP1500PFCLCD-Sinewave-Compatible-Mini-Tower/dp/B00429N19W This provides for an independent power source without a risk to your battery/electrical system. Obviously there are portable generators. The 110v socket in the truck appears to only be 1 amp (150w) which is not much. If you have a dual battery, then I guess you could drop an inverter on it and try not to fully drain it. That said, I think I would rather just get a big ups than muck around with lead-acid car batteries and an inverter.
My own goal is an UPS when I need to be quiet or low power requirements and a small ultra-quiet generator for charging the ups and more power intensive stuff. I prefer the leave the vehicle electrical system as is (except for basic phone/etc charging).
I understand there will be various opinions on this subject. <g>
What are you plugging in to it and how long does it last you?
I ran two ARB refers (60 & 40 qt) off my sockets I put in the bed of my 08 Silverado, which tapped into the "always hot" trailer wire. It ran them no sweat and left them plugged in for a month once while driving daily. I used to charge my gps dog collars at the same time. Very convenient. I intend to install 3 sockets on this truck near the tailgate on the left side. The ARB refers are ac/dc. I wouldn't mess around with ups and inverters for them. Putting 12v sockets in the bed is a cheap, quick mod that is a must-have mod for me.
Try looking at marine stores, they have some waterproof 12v outlets with different mounting looks.
Some computer/electronic devices that requires clean 110v power. Duration is based on usage, about two hours in my case.
There was a reply related to using a device that required 110v power. For 110, stuck with a portable generate, an ups, deep cell battery/inverter, or even the 110v socket in the truck if available. For "me", I prefer not to tap the truck electrical system while stopped for 110v power.
