2004 gmc sierra denali quad steer
Looking for rear end parts for 2004 Quad, I have replaced the position sensor and calibrated the rear steering.
GMC claims they don't make replace parts anymore? Can anyone advise if there is a aftermarket source for seals and other parts?
thanks
I'm pretty sure they don't make parts... It'll be tough but try searching craigslist and call around scrapyards for parts.. Probably your best bet.. Or buy another quadrasteer truck as a parts truck.
car-part.com
Some parts on the Quadrasteer system can be purchased new, albeit expensive. The rack housing is no longer available. You need to find a decent condition one used.
Best of luck.
Also:
Look at denalitrucks.com for Quadrasteer related info. They have everything you could ever need.
Do you know the fault/s in the system presently (ie: chassis codes)? I might be able to help you. Recently, my rack failed and I needed to replace the whole thing. Did a lot of research. Found what I could for new OEM parts and the rest I had to get used.
Are you kidding? Would I have been Pissed if I put the cash out for one of those back then when they were touting them as the next best thing and they won't even support them 10 years later.... I mean they ,may not have been popular but they do function as they are supposed to ....
Hope you find your parts....
You're absolutely right. The level of frustration that Quadrasteer owners have with GM is unreal. If you bring a QS truck to a GM dealer, they will likely put a new rear position sensor in without really knowing what the problem is. If that doesn't work, they call the GM hotline and GM tells them to pull the QS fuse and just disable it. If you're lucky, you'll have a shop nearby with a service department that is savvy enough to work with you on the repair and do what they can. That's a rarity though.
So you basically have to DIY the whole thing with good condition parts from recyclers and try to stockpile as many leftover OEM parts as you can. It's not terrible but GM should have allowed for a little more support on this system.
As I understand it, Delphi was trying to make a 2nd gen QS system and they had the prototype ready just as GM killed the idea altogether. Delphi's branch that worked on the QS project is now Newsteer or something like that. They won't respond if you ask questions about the system. They don't care.
if it wasn't for denalitrucks.com, I would have sold the truck when my QS died. Now that it's fixed the truck feels awesome. It's tough to go from a 4WS truck to 2WS. The difference isn't even comparable.
