Dyna Beads?
Anybody here have any experience with Dyno Beads or a similar product? I've heard good reviews (and it's cheap enough to try) but I wanted to double check. I'm having a slight high speed vibration that's a little bit annoying with the new wheel/tire setup... already rebalanced (road force) and it helped but trying to get it perfect.
Never heard of them but pretty interesting concept
Sent from my SM-N900T using Tapatalk
I've never heard of dyna beads. At my work we use a similar product called equal in our semi tires and it works. I don't see why dyna beads wouldn't work too.
We have them in both of our 2014's on 20" Rims and 35" tires. work great.
I've used them in pickup truck tires...results will vary. I had good luck with it twice, and no luck with it twice.
I almost think it depends on the tire (one that is mostly true will balance better than one not so true) and suspension (better suspension keeps the beads from getting thrown around at every bump).
Its one of those things that you try and if it works great, if not your out about $50 to dismount, remove the powder, and balance normally. I personally wouldn't do it again, although I did get over 150k out of a set of lt265x75r16 michelin LTX A/S on the truck that it did work.
I've been using them in motorcycle tires for the past couple of years without issue.
Ive heard of some guys using them on track bikes, this makes it so they dont have to tape wheel weights on.
i was lucky, my PP3's i put on my cbr balanced perfect without any weights for the rear tire, front needed 1.
Used them on my bike, had great tire wear. If they dont work you probbly just need another oz of beads
    C. Hart
    C. Hart
  • Who's Online   3 Members, 1 Anonymous, 464 Guests (See full list)
