Hello Everyone - New GM Guy from Ontario Canada
revitupfaster
Hello everyone. I've been a Chevy guy all my life, and I just recently picked up my new 2014 Silverado, and since I did a lot of research on it using this forum, which was very helpful, I decided to sign up, and hopefully be able to contribute something as well.
I live in Southern Ontario Canada, just about 40 miles from Buffalo NY. I'm retired, and still have a great passion for all things Automotive. I'm a strong Chevy Guy having had many Silverado's, and my fair share of Monte Carlos........too bad GM dropped the MC. Would love to see a new Monte, based on the new Impala, with 2 doors and a small V8.........sign me up.
Anyway, here's a few pics of the new ride.
REV
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
