2015 Denali 3500 - 20" wheels?
2riskit
Yes they will work, but they didn't offer 20's with the GMT900 3500's because the load rating isn't nearly as high with 20inch tires.. Just something to beware of
Thanks! I tow a conventional trailer that's only 7500lbs fully loaded and don't really load the truck up at all but I'll keep it in mind just in case. :-)
