replacing brake light switch
I just replaced the brake light switch on my 08 GMC sierra hoping it would fix not working cruise control problem. still not working , there is a engine icon lite on. I didn't disconnect battery to do job. should I have. Is there any adjustment I should also do. Any help would be appreciated . Thanks for your time.
didnt have a check engine light when it was my brake light switch, have the light checked, thats probably your issue.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
