GM's ancient 6.0L Vortec whoops up on the 6.4L HEMI.
galliher_nc
It’s not every day that TFLtruck gets an opportunity to compare similarly configured trucks, with the same load, and under conditions. The 2014 Ram 2500 HD Crew Cab 4×4 Big Horn you see here is $210 more expensive than the 2015 Chevy Silverado 2500 HD we recently tested.
We had the same load behind both trucks. We adjusted the bed weight to compensate for the absence of Emme Hall, and the final weigh-in showed that the Ram and Chevy were within 100 pounds of each other for the Gross Combined Vehicle Weight (GCVW).
The weather was about the same. It was 72F during the Ram test, which was three degrees cooler than during the Chevy test."
"Even the rear-axle ratio was the same on both truck at 4.10. The big 6.4L HEMI V8 is the most powerful gasoline engine you can get in the Ram HD. It produces 410 horsepower and 429 lb-ft of torque. It’s backed up by the 6-speed automatic transmission.
The stage was set for the closest, most apples-to-apples HD truck comparison. However, the result was surprising. Check the data and the video below."
http://www.tfltruck.com/2014/10/2014-ram-2500-hd-6-4l-hemi-vs-6-0l-chevy-ike-gauntlet-hd/
Interesting. I couldn't sit through another 30 minute video to see if the Chevy slowed down as much but despite their claims the engine shifted to too-low an RPM the Chevy clearly does better.
They needed to stack and triple flip the mirrors to activate the extra 100hp/tq tow mirror mode. If TFL actually knew what they were doing once in a while, jeez!
That was sad. I haven't seen any actual power curves from this engine, but if it's anywhere near where it's rated it should have done better than that. If there was something wrong with it putting it into power saving mode for some reason, you'd think a check engine light would have illuminated. That said, the 6.0 wasn't very impressive either.
I really want to know how this truck passed the tests of SAE J2807 with that load. After seeing the GM test I doubted it would pass, but the Ram was so pathetic there's no way in hell it could pass with that load.
While the Davis Dam portion of that test is at lower elevation, it's at 100+ degrees so it's not much easier. I don't think either truck could keep that load above 40 MPH in such a test. They'd fail. The GM doesn't claim to be rated for it but the Ram does. What gives?
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
