Removing "Instrument Panel Fuse Block (Right)" ???
The manual states:
The right instrument panel fuse
block access door is on the
passenger side edge of the
instrument panel.
Pull off the cover to access the fuse
block.
With a nice picture with the cover already off.
Okay, and just how do I pull off the cover? I tried pulling from the bottom and not successful (I only pulled a little as I didn't want to break anything). Would be nice if the manual provided where to pull from information.
Has anyone removed the right side fuse panel? If yes, how did you do it? (And maybe a video would be useful :) )
Have had mine off a few times and it is real tight. Takes a good bit of pressure to get it started.
