Senior member?
timk49
I just noticed the caption above my avatar. Come on now guys. I know I've been around longer  than a lot of the young men on this board, but Senior member, Heck I'm not that old yet.
haha, Tim. Its not just you. You automatically get that title after so many posts.  :crackup:  :crackup:
Hum............ Maybe you mistaked the question......
How many posts do you have to have to be able to make your own custom name like "Ahh........." or "Mod-Wild"?
Thanks for the reply though.........
Well I had no idea it was a reward for posting. What do I get for 200 posts?
May I take this opportunity to thank all of you guys who have helped me learn more about my truck with your informative posts. Thanks Guys.
Hey congrats Tim.
This is totally off topic, but awhile back someone posted a picture of a 2K3 in pewter, taken from the left side, showing off some new 285's.  Was this your truck?  If so, do you think you could post that picture again.  I have searched over and over and can't find the thread.
Thanks.
You should get medical help because now you're addicted to this board.  This place is like a bag of chips and it seems like you're hooked.  You should see what it's done to poor Frank....... :crackup:
Yea I know.
Just think, if I  weren't here, I'd be driving a Bronco by now! :crackup:  :crackup:
Hey congrats Tim.
Thanks.
Is this the one your looking for Bowtiebob? If there is another you need just let me know. I'll try to get you a specific one if you need it.
