driver mirror went bye bye
hello all, new to the forum, really enjoying my 2014 sierra and all the content available on this site.
i lost my mirror and need to put the new one in, any instructions available.
thanks in advance
awesome find on the book cover, but unfortunately mine was more akin to blunt force trauma, followed with an amputation.
some might say that the other driver had a bigger mirror than me, hate to admit it.
thanks, I'm like an immigrant version of Norm McDonald sometime.
but back to the mirror, no takers. I'm too busy to dwell over this next weekend with my beers, it usually costs me ten fold completing tasks in this manner. last weekend i had a semi tow truck pulling a friend's loader out of my ditch.
Check the Tow Mirror thread in the accessories section of the forum, there are removal instructions there...
Sounds like you should find a good craft brewery with an acceptable mechanic close by.
