i recently ordered a bulk shipment of summit white automotive vinyl through a local supplier. I have quite a bit left that I'm not going to use ( i covered my grille, front and rear bumpers, mirror caps, and handles in it) So i figured id see if anyone on here was interested in the remaining roll ( i have 8ftX20ft roll left in perfect condition) Im looking to get $100 for the roll which i think is pretty reasonable as i paid around $400 for entire roll when i ordered it which was 8ftx40 originally. Let me know what you think and if you have any questions.
Thanks :thumbs:
I'm only looking to do my mirror covers and handles... You want cut and send me some? Shoot me a Price?
Sent from my XT1058 using Tapatalk
im located in Illinois, it is automotive vinyl that has a special backing that has "air release" properties. therefore all you have to do is apply a little area at a time and smooth it out, then using a heat gun heat the area and any bubbles it may have will disappear. the best part is its made for "beginners" so if you mess up or crinkle it all you have to do is lift it up, go over it with the heat gun briefly and the material will return to its original shape.
Man I want this...but I'm too scared of the install and messing it up.
you really can't mess it up, honestly, this style vinyl is a "beginners" style so it has allot of forgiveness. Look up some videos on youtube. if you you mess up a piece literally all you do is lift the vinyl, run over it with a heat gun and it lays flat again just like it was when you started. Its pretty neat seeing it do it actually.
I'm more concerned about cutting around the plastic trim inserts and such on the bumpers for a perfect fit...
oh you don't cut around them, take the plastics off; clean the bumper real well with a ammonia free cleaner and start wrapping then reinstall everything. Stuffs great, shines just like the paint, its wax-able just like paint, ect...
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
