Advice on mods for my 4.3 sierra sle
Jlevita82
This is my first truck and there's so much I want to do. Just not sure what order or what's best. I got the 4.3 because I wanted the best fuel efficiency possible. The mods I want are
paint the bumpers and grill to look like AT
Slt headlights
Leveling kit
Black "gear blackjack" rims and tires idk what size is best
Intake
Exhaust
Nerf steps
Then of course the little mods
Darker tint
Sub
Maybe wheel flares
Can I get some advice on which mods should be done first and what's the best brands and sizes to use.
Thank you jason
Let us know what the fuel mileage does when you put big tires on it. Not too much info on modified 4.3L trucks.
Yeah I can only imagine my mpg will be much worse just wondering what size rims and tires would look good yet keep decent mpg. Also I don't want to go cheap with a leveling kit which one would be good? I've been reading posts and people put they are getting 2.5 in the front and 3 in the rear but isnt it suppose to be the opposite?
The limitations on a "leveling" kit or shocks is the CV joint angles (4wd). To me, "leveling" means something (spacer or shock/spring) that pushes the suspension arms down further when in the resting position. That puts all the components in a more extended position and also puts more angle in the CV joints. A 2wd truck can probably get away with a bit more angle on the A-arms, since there is no drive axle and CV joints. But the geometry of the suspension can get out of wack and ride quality can be messed up if the springs aren't changed to something softer.
For a 4wd, I'd try to keep it under 2 1/2" on a "leveling kit".
Bilsteins 5100 adjustable height shock, Fox, or King shocks would be the top drawer methods. Bilsteins would be the cheapest of those three.
Thank you for the response. Very informative. I just like the off road look but I'll never actually go off-roading. I just don't want to go cheap on it. I guess it's going to be all show no go.
