New to GM
Roundrobin
Hi friends,
Just bought my first GMC truck. A single cab 6ft 4" box, lifted and fully loaded with V-8 and HD towing. What brought me here was my search for a driver seat lift kit. I am just 5ft 9" and I feel sitting a bit too low. I was surprised to see no adjustment for that. Anyway, other than that I love the truck. Bought it used with only 18,000 km so it and full Warranty
Cheers to all and I will try to participate lots. I am a retired Canadian Air Force veteran and now fully retired.
Cheers
Al
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 544 Guests (See full list)
