I don't get why they got rid of them. I mean, I have puddle lamps on my mirror, but no footwell lights. Doesnt make sense haha
Sent while in 'Murica...
After I get my other truck off the jack stands (hopefully before the end of the week) I'm going to tackle the footwell led and hitch led lights. For the hitch I'm going to have my buddy weld 4 tabs to the hitch; 2 aiming straight down on the hitch and then 1 on each far side aiming towards the hitch to provide light for hooking up a trailer at night. Luckily the bed lights are wired at the rear, so tapping into them wouldn't be hard at all.
My buddy also suggested to get an led strip to put on the down angle of the bulkhead to light up the front of the bed since the cab lights don't work too well there. It will also be good for if I install a soft roll up tonneau cover, the whole bed will be illuminated.
Here's the leds I bought:
Hooked em up to a drill battery and they put off a serious amount of light for something so small. The company claims they are waterproof which is why I want to use them for back at the hitch
Installed low and high beam HID's. Everything tucked away nice and clean
Also installed weathertech in-channel rain deflectors
Currently in the process of painting the front emblem while the grille is off the truck
Looks good kinda jealous but you can't mess with money. Lol
Lol and thanks! Your truck is closer to being payed off so that's a plus!
What HID kit did you go with?
DDM tuning 35w 5000k with harnesses for both high and low beam and error eliminators for the low beams. I'll get a night shot here soon. Much better than stock that's for sure. Makes these new k2 front clips really "pop" with the white light
Edited by rdnckhntr94
Just ordered weathertech floor mats front and rear. Should be in by next week sometime. Part of my Christmas gifts, just a little late
Also failed miserably 3 times trying to plasti dip the front emblem. Looked killer but started peeling up in one corner every time, or I missed a few spots. Giving up for now. Debating on taking some gloss black rustoleum to it or not...
Im suprised to hear that it's not sticking. Did you try cleaning it before hand with rubbing alcohol? I did the ones on my Wife's Cruze with no trouble which suprised me.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
