Maybe the screen name threw me off lol. The hair looks spot on though [emoji1].
I have a hat on? Maybe I'm just not picking up on something lol
Just my visual in my head... I worked last night and haven't slept. My humor game is off today.
I was thinking the blank outer space DUH look. Lmao. Just kidding but the truck looks good can't wait to see it leveled.
Alright, so ignore the really crappy paint skills because I'm on my phone lol. Did a couple different ideas and feel like they are all pretty slick looking:
Stock:
#1 (4x4, steps, high country emblem gone):
#2 (everything chrome gone except mirror caps and door handle. 4x4 also gone):
#3 (steps, door trim, 4x4 emblem gone. Kept the high country emblems):
Delete "Most" chrome, leave all badges and markings
I think it looks gooder without the 4x4
More gooder
My vote is for #1. Remove 4x4, steps, and HC emblem.
Of course, I could be biased towards that option since that's what I did and I think it looks good.
Most I've done to it in a while [emoji3]
Stock:
2" level and removed those obnoxious steps:
I use to have to step to the outside of the step in order to get out and it would cause me to slide off the side of my seat and wearing it down quicker than normal. Now I can step straight to the ground and push myself up on the way out of the door so I don't wear out my seat anymore!
Alignment gets done at 3pm tomorrow should take about an hour! Got a small road trip ahead of me this weekend (about 2 hours one way) then we'll see how I like it!
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,253 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
