Light bar setups
What are you guys running for led light bars? I have a 2012 I'd like to get some more lights on. Looking for a bumper area mount so I don't have to drill holes in the cab (do try have ones that mount like off the tow hooks) and how did you guys wire them up?
Are light bars legal ? , idk , just askin ,
I saw one on a truck and wondered how bright they'd be ..... Cuz I love blue lights so much comin at me ,,,,, not !!!
Legal, probably not, I'd just turn it off at the sight of a car coming, till the moron don't drop their high beams and I'm sure it's not a cop, then hello daylight!
Here's one I was linked to. Anyone use this one (or same but smaller)
www.amazon.com/Eyourlife-30000LM-Light-100pcs-intensity/dp/B00F4MQJ5O
I seen some mounted behind the front grill and I really admired them. Could barely even see them.Thinking of doing that myself just to have fun with it. Good for backroading!!
I did mine behind the grill out off sight
How well does the light shine through the SLT grill? I thought about it, but worried that much of the light would be blocked from the thick grill.
i can now see almost 1/2 mile signs reflect back about 1 mile away the bar is 15000 lum
Thank you sir!
I added a 30" bar behind the grille. Mounted it right to the radiator supports
It looks very clean!
I also added a bull bar with a 20" bar, but I'm not too sure I like the bull bar. I might mount the 20" behind the grille somehow and keep the front end flush and clean.
Wired it all to a wireless 12v switch I got from Tractor Supply. Saved a ton of time running wires into the cab and was only $30!
Works flawless and they are super bright!
Nice. That gives me lots of ideas now. Mind showing where you have the switch mounted. And. Did you run a relay. Or just a straight wire from power source to the switch then to light? And what are you using for a power source?
They are for off-road use only but.............. great for back-up lights, hunting,pissing people off, like train horns !!!!!!
I want some.........
I mounted my 20" dual row in the bumper slot. I like how it looks
2011 silverado LT crew
Gibson cat back, Airaid Jr
Kooks 1-7/8
long tubes and y-pipe, blackbear tuning, rough country 2.5", go rhino dominator 2 steps
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
