Rattle
So I've been hearing a rattle that sounds like it's coming from underneath/driver side. I looked and found the exhaust was fine, but the fuel cell undershield and the fuel purge valve assembly (may not be correct names) are very flimsy and cause this rattling noise. Noise appears more during a cold start. I've attached a pic of both rattling things. 03c47c304464f58c148a131d7cce0696.jpg
Hello TX15Z71,
I see you're reaching out regarding the rattling noise in your 2015 Silverado. Although I'm not trained as a technician, please feel free to send a PM if you decide to take it in to get checked out. I'd be happy to reach out on your behalf and research this further.
Sincerely,
Eddie A.
GM Customer Care
Can you make a video of the sound? These trucks have two fuel pumps and the high pressure one under the hood makes a rattling type sound during cold startup. If this is indeed your sound, it's normal. I thought the noise was the heat shield initially.
It's hard to tell. I went outside and tried to record it, but it didn't make the noise. When we had the truck in the lift we started feeling around and those two things I put arrows on were making the same noise.
Noise is coming from the exhaust flapper valve. Most people just tie them open. There's a thread somewhere on the forum about it.
in the picture you posed the object that your finger is touching in the charcoal canister just FYI.
Not sure I understand what you're saying. Please explain.
What's there to explain??? The object you are pointing at in the pic is the charcoal canister FYI (for you information). Regardless, that's not where your sound is coming from and it's more of a squeak than a rattle. As I said, it's from the exhaust valve and none of the pics you have arrows pointing too.
I guess I didn't understand because you don't write very well, but I dumbed myself down 80% and figured out that when you wrote "posed" you meant to write "posted", and when you wrote "in" you meant to write "is". Now it all makes sense.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
