2015 DIC off road graphic
Okay I'm new here and I have a question. Last Friday I bought a '15 GMC Sierra 1500 crew cab 2wd SLT. The truck has this off road graphic that show steering angle, as well as vehicle angle side-to-side and front-to-back. I have seen this work driving around on my property at low speeds but I. Can't figure out what triggers it. Can anyone help me with this.
you can set it to display with the steering wheel controls
its in settings. I have it added as a page on mine so I can just arrow down to it.
I have not had my turn on automatically.
I would image it turns on at some extreme angle.
Why would a 2 wheel drive have an off road package?
I'm with you on that. I have added mine to the 'scroll list' and mine doesn't come up automaticlly. Sorry for the confusion. I had the DIC page on driving across my property and I could see the angles change with steering input and as I went up and down hills. However, when I driving down the road the page doesn't do anything. All the angles are zeroed out like the page is inactive.
its active... truck isnt moving enough.
I was going over a pass in Colorado and it changed.
Strangely the pass was a 7% grade and the screen showed 1%
I don't know if it is off or what.
I planned to look it up in the manual but forgot.
It's just inclinometer. Readouts are probably calculated from outputs from longitudinal accelerometer, yaw sensor, and steering wheel angle sensor. I believe it's part of the Z71 package. Remember that Z71 package is not limited to 4WD.
How does it get onto the screen? I have the Z71 package on my 2015i GMC 2500 HD SLT and wondered my self how it appears.
Sierra Boy
With the new trucks 2014 and 2015 I did not think Z71 was available in 2wd like the previous years. But I wish I could add this readout to my 2014!! I even have a page that literally reads "Blank Page" in my DIC.
Mine has worked several times and I have 4x4 Z71. It wasn't in 4x4 when it activated . Helps with uphill acceleration and downhill. But when you have 4x4 in gaged and the setting it works like a champ. No slip or extreme acceleration to slide out. It will only pop up when active going downhill or up hill on freeway when cruise control is on. Or if you turn it on manually with the button with 4x4 to help down extreme angles or up etc.... 262c74baffa83122141e45586dddf8c4.jpg
You can delete the blank page too.
I did not know that....I will have to play with it a little but if anyone knows how please post.
Info under 'Vehicle Personalization' in the Intsruments and Controls Chapter. This areas is where things like 'rear camera lines' are enabled or disabled.
Uplevel Radio Audio System
Controls
1. Press the desired feature to
display a list of available
options.
2. Press to select the desired
feature setting.
3. Press o BACK on the faceplate
or the 0 screen button to return
to the previous menu or exit.
Turn the vehicle to ON/RUN to
access the Settings menu, then
select SETTINGS from the Home
page on the infotainment system
display.
DIC INFO PAGES (including the blank page): this area selects which pages show up when scrolling thru dic info.
( cut and paste changes the steering wheel arrows. ( o = left arrow, w=, x=down arrow and V= check mark) and I don't know how to correct)
DIC Info Page Options
The info pages on the DIC can be
turned on or off through the
Settings menu.
1. Press o to access the cluster
applications.
2. Press w or x to scroll to the
Settings application.
3. Press V to enter the
Settings menu.
4. Scroll to Info Pages and
press p.
5. Press w or x to move through
the list of possible information
displays.
6. Press V while an item is
highlighted to select or deselect
that item. When an item is
selected, a checkmark will
appear next to it.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
