I also bought the auxiliary switches for my 2016 Chevy Silverado 1500. I hooked one wire from one of the switches up to the 86 terminal on the relay. The 85 terminal is connected to the positive post of the battery. When I flip all of the switches, nothing happens. Did this happen to you?
I’m telling you email smcgillis10 he will make you the relay/fuse box you need .. he really helped Me out .. very knowledgeable dude ..
Need some help,
I have the cargo light, T/C, and 4 aux switches. I have routed the buttons out to the engine bay. I have connected a... relay box (one relay box per switch). Currently each relay (12V, 30A) is set up as such
Battery -> fuse-> relay pin 30
switch(aux) -> relay pin 85
light bar -> relay pin 87
Ground - > relay pin 86
with these connected as such the lights on my switches turn on and do not turn off no matter what.
When I push the switches the light bar does not turn on. I have switched things around but have gotten nothing.
any insight would be appreciated.
Did you hook it up to aux 1? If that doesn’t work, try a different switch. The aux switches are ground controlling. You need to hook the 85 pin to the positive post of the battery, then the switch to the 86 terminal.
  • 5 months later...
I have upfitter switches peddles/tc/cargo lamp/park assist/ldw/hdc/running boards and I configured my switches swapping out hdc with an aux . The hdc (aux) is a non functional switch no wire present I would like to have it function as an on and off switch how can I go about achieving this
On 3/17/2016 at 6:08 PM, arkiehou02 said:
Thanks. That helps out. I am just going to tie the pedal up and down together as the switch for that button. That sounds reasonable. It won't have an indicator but I plan on using it for RGB halos that I want on all the time. But I still want the capability to turn them off. I will use the NO function on the latching relay and the button push will turn them off.
I know this is old but hope you get it lol.  I did this about 5 years ago and only used first 2 aux for lights.  Now i want to use another and i was reading this over again and I am wondering if i did the indicator lights wrong.  I do have it all working I use one latching relay for the relay to the light bar and another for the indicator light.  So thats 2 for each switch. I have 4 hooked up now.  This does work,  But i see you say here to hook up the indicator to NO function and it will turn on and off with the switch .  Does this work for you?  I would help me out as I would not have to add another relay just rewire what I have
On 4/26/2018 at 4:17 PM, TinkeringFox said:
I just tested an Upfitter switch with a CNG button (23146445) and it seems to be identical to the one with TC,Cargo,Exhaust Brake (23145163?). The output and indicator input use the Exhaust Brake plug (X2). If you were to use this CNG switch, or the Exhaust Brake switch inyour application you would need to remove terminal/wire 4 from the X1 connector (main plug) and swap into pin 4 on the X2 connector (exhaust brake plug). The terminals are a different size so a cut and splice would be necessary or just replacing the terminal. This would allow the use or triggering of HDC through the Output pin from CNG or Exhaust Brake. You would just pop on an HDC cap in place of CNG, then move the CNG cap to say Aux 4 to use as your slip tank Trigger.
How can i get pin 4 & 5 to work like AUX 1 & 2 did?  The exhaust brake doesnt work like them.  There is 12v+ initially, then when hit it it goes to zero volts.  I dont know what CNG is but all i need it to do is turn on a latching relay when pressed, then turn off the relay when pressed again.
So i guess no one is watching this thread anymore???
I’m watching but I have no idea what you need to do to achieve what you’re looking for.
lol, well thanks for replying... I dont know what to do, Its like these two switches are reversed polarity for what their function used to be I suppose.  But if i reverse the polarity to the harnness (which i am only using it for AUX 4)  it may screw up the indicator light which is working fine.
What i need is something to reverse the polarity before i get to the latching relay, because everything other than that works fine.  I thought there were others here that got the exhaust brake swithc working for something else other than that function...
  • 10 months later...
hello everyone. i am new here. recently i just bought a 2017 gmc 2500hd denali fully loaded. however, the truck is already in the shop. the ? i have  are these switch panel small enough that i can possibly retrofit ( custom fab ) into the roof console using the sunglass compartment to make it look factory etc, any help would be awesonme. but i need for sure a momentary switch. and couple of latching switch. i ordered all on board air kit with train horn and airbags for it. but i have no space avaible on the orignal switch panel since this truck is fully loaded with all the goodies
   I don't have any pics of mine handy (not on my usual computer, with my vehicle info), but I know some guys have put rocker switch panels into their roof consoles.  Even the big rockers like these:
AMAZON ROCKER SWITCH PANEL
This style of switch has a rear depth of 1.43".    So there is at LEAST that much clearance up there.   But you may have to bend the spades a bit to accommodate the female terminals on your wires.
bump
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
