Moving Tire Sensors.
You do NOT have to take the tires off the wheel to move tps to new wheel.
1. Default the tire.
2. Push the side wall in with a tire machine.
3. Unscrew the sensor.
4. Inflate the tire.
Any tire shop will do it for free, if you bought tires from them before.
My shop knows me so no questions asked.
I have no idea why so many people think it is hard to move those.
I moved mine yesterday.
**Note:
On very low profile tires like the ones on my corvette the tires do have to come off.
There isn't enough sidewall flex. That is not true on any of the truck tires.
When doing tire rotation the tire shop has to reprogram the positions.
This is also free of charge.
  • Replies 59
are you referring to when I have my tires rotated, my DIC shows my tire pressures as bass ackwards? haha
I'm pretty sure the truck just needs to relearn the tire position. No way the dealer is moving sensors around. That would be a huge design flaw for a tire pressure monitoring system if the sensors have to be relocated from one wheel to another every time you rotated tires.
I'm lost does he mean every time u rotate tires this has to be performed ?
I understand the OP to be saying this. I could be wrong.
I'm saying no, this doesn't have to be performed.
I think the OP is referring to people that are looking at or have two sets of wheels and how easy it is to move between the sets.
Oh ok that makes more sense.
to new wheels.
When rotating tires your tire shop should reprogram them.
Ahhhhhhh....... Ok.
I don't see how it's that easy. On my last truck with 275/55/20 stock size tires, I had a slight air leak around the bead (rim lip). I deflated the tire and I could barely get the tire's sidewall to budge in order to clean inside the rim lip.
I would be worried about re-inflating and re-sealing around the bead.
Its your money... feel free to waste it on new tire pressure sensors.
Or call and ask ANY, yes ANY I dare you to fine a real tire shop that says
you need to buy new sensors.
And you can do it at home, but I am not going to explain how to break a bead on a tire to this group.
If you want to know that, ask a jeep forum. They change tires on the trail pretty regularly.
Mine were moved yesterday by Discount Tire, for Free. TPMS works fine and both sets of tires work fine.
And yes they hold air... amazing that I bead can be broken and then re seated.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 404 Guests (See full list)
