build time?
I'm sure this has been covered here, but I'm a new member and I was wondering if anyone has ordered and received a new truck this year? I ordered mine on Jan 19th and GM says it will go into production Feb 16th. Anyone know how long it takes from there?
2015 1500 Denali, 6.2 crew cab standard box..
I've read on here it sometimes depends on certain options or rims as to how long it will take. As above, it could be as early as 2 months after putting the order in or could take longer. I guess the good thing about picking one out of the lot is that I was able to drive it home right then. I just wish I had different axle ratios, but everything else is exactly what I wanted, even the color so I guess I got lucky. I don't have much patients so I don't think I could take waiting on a truck to be built lol.
Mine took like 6 weeks once build started, but because I ordered 6.2 in November 2013 that didn't start right away. Crew cab is made Mexico and I'm in Florida. Might help some.
Ok thanks everyone. When I ordered my 08 sierra I was able to track it online through the build process. Looking around here it looks like the best option is just calling GM every few weeks to find out updates.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
