Duramax Engine Rattle-Knock
I purchased my new 2015 Sierra late December and it has about 2500 miles on it (Diesel Option) and while going up through the gears on acceleration if I did not know any better I would think the motor was gasser and it had bad gas because it sounds like spark knock. I have been told (not real versed on this so I might be talking some smack) this is due to the pilot valve which is used to help eliminate turbo lag. I had my 06 Duramax which ran like a scarred rabbit no turbo lag and no knocking. Just wondering if anyone else has had or heard of this issue. Any help would be appreciated.
That doesn't sound normal. I would take it to the dealer and have them take a look. You could also drive another duramax and see if it makes the same noise on acceleration. We have a 14 LML duramax in the family and it has been smooth and quiet (for a diesel). Has had no problems whatsoever, currently at 18k miles.
Duramax injection systems fire multiple pulses per rev at lower rpms. One of the things this does is reduce the amount of 'injection noise' compared to older diesels.
Under hard acceleration at higher rpm use of this technique is reduced/suspended and there will be more injection noise.
  • 1 year later...
I have a 2016 3500 dually. I just noticed the noise today on highway. When I cruise at 65mph and slightly press the gas the starts rattling and nocking then it normal...soon as I press gas again it rattles, but on idle does not do that..I'm gonna take it to the dealer let them check it out.
Very rare to hear any knock/rattle from my Duramaxs. Could be a few things. Does it do this on different tanks of fuel (could have some bad stuff, maybe try different pump station)?
i heard a rattle from my truck not to long ago and it turns out that there is an oval thing sitting on top of the engine dead center that as the dmax 6.6 logo on it. there is one bolt on that piece that faces forward. mine had come loose. i just snugged that up and my rattle went away.
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,346 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
