Spongy brakes issue
Good Evening,
I have a 05 1500 Silverado Ext Cab with rear drums (138,000) and I am having a braking issue that I am trying to diagnose. My current setup:
Power Slot Cyro treated Rotors
Hawk LT pads
SS brake lines.
I have bleed the system twice. First myself and then the 2nd time I took it to a shop. After the 2nd time, the brakes on the truck felt great for about a month or so but now the spongy brake issue has come back. With the truck off I can press the brake pedal and load of the lines and they will lock with no movement. When I do drive, I have to push the pedal father to the floor then before but the truck will stop. When I do press the brake pedal, I hear a loud hissing sound from under the dash when pressing the brake pedal. I have read that this trucks have rusty brake line issues and I am wondering that the rusted lines is introducing moisture to the brake system.
Had anyone ever experienced this or any thoughts on what it could be?
The hissing could mean a leaking brake booster if you have a vacuum booster.
The actual brake booster itself or maybe the check valve?
Start the truck and let it run for a min then shut it off. Wait a min or so then pull the check valve out of the booster and see if there is still vacuum. If not you probably have a leaky booster. That's not a common issue on these trucks but neither is the problem you're having.
I did a quick check of the lines and yes some of them have rust on them but not that bad. I pulled the check valve and it made a loud psst sound so I am assuming I had good vaccum. Possibly the MC is slowly going out. Debating that if I am going to change the MC I might as well change the brake booster also. Just kill 2 birds with one stone.
Make sure that your rear shoes are adjusted properly. Excessive clearance will cause a low pedal.
bbwb
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
