Where is this located?
Crawl under your truck by the passenger seat and look up kind of in the middle and just behind the engine bay....you should see a black hose or drip tube hanging down. Guessing 3/8" diameter. I need to figure out a way to shoot compressed air in mine.
Bought a cheap air compressor at lunch today from Lowe's. I'm going to try to blow out my condensate line tonight after work and see what happens. I'll report back.
I was wrong man it's behind the passenger side wheel well liner about halfway up the firewall. A black rubber nozzle sticking out and turning down 90 degrees like an elbow fitting. And I guess mine is draining fine since this is where I saw water on the frame the other day and the wheel well miner was wet....I had assumed something over flowed. I'm going to get my mechanic to shoot air up there while it's in the shop tomorrow just to be safe. I really feel like the truck used to drain more water. There were noticeably large water spots on the ground and I just don't see them anymore.
Edited by Silverado-Hareek
  • 3 years later...
Any updated on this? Mine has been doing this starting last year, I've tried cleaning the drain and this does not seem to be the problem? Logic tells me this is bubbling from inside the heater core - because it will start to do it almost immediately on startup...
Thoughts?
Thanks
-Ryan
  • 5 years later...
My 2018 sierra Denali 6.2 does this occasionally upon initial start up. Then stops roughly two or three minutes after it’s been idling. It comes from under the truck roughly around where the transmission is. Would this be the same issue or something different?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
