New from Edmonton
Hey all, I'm Jeremy and been on here checking out the forums for a while now and finally joined about a week ago. Love the forums so far and its great to see what people think of what GM's doing. I admit I currently drive an 03 Cavalier POS but have a 2015 Silverado Double cab 4X4 WT Blackout Edition on order that was placed around the 5th of March. Hope to see it by mid-late April. Anyways, that's my little introduction. Bye for now everyone!
Welcome to the group Jeremy, congrats on the new truck. Love the Blackout Edition!!
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
