22 inch magnaflow muffler
zack89
Just installed my new magnaflow muffler last weekend. It doesn't seem to be much louder in the cab and has a nice rumble when taking off.there's no drone what so ever.I've also picked up at least 1.5 mpg better. The throttle response seems to be way better the more I drive it and doesn't seem to be as lazy anymore. Just got my local muffler shop to weld on a reducer on both side then i used 2 clamps and called it good to me about and hour to install
I'm about to buy this same muffler, I really want something a little louder than stock, but definitely don't any drone. Could you possibly post a sound clip
I installed the same muffler on my 6.2. Had the old muffler and the flapper valve cut off and dropped the 3.5" in 3.5" out Magnaflow in place. No drone, not much louder in the cab, nice growl when I stand on it. I hadn't had the truck long enough to really see any change in the mileage.
What does it sound like in v4?
Rolling down the highway it goes into V4 and I don't really hear any difference. Since you're not pulling or under load when it goes into V4 there isn't much exhaust note anyway so there's not much to change.
There is a few videos on youtube already and theyre spot on how it sounds I'm supper happy with how it sound when I get on it it has a good note to it but other then that it's quite which is what I wanted
    Fishboat
    Fishboat
  • Who's Online   7 Members, 0 Anonymous, 491 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
