04 Trailblazer fuel in airbox pre throttle body
MikeInCtown
04 Trailblazer with the 4200 I-6 engine. has 118,000 miles. While trying to change out an oxygen sensor I noticed a fuel smell. I found that the box on top of the engine (labeled with the vortec 4200) had an amount of fuel in it. (probably 1/8" on the flat bottom surface) It is the box between the flexible hose from the air filter and the throttle body that you see in the photos.
I am trying to figure out how gas can get back into the air system when it should have the injectors putting the gas directly into the intake. It looks like there is a small vacuum line on the front right side of the box as well as a larger 1/2" or 3/4" rubber hose coming from either the valve cover or possibly the manifold. Also, the fuel remains there even after a long drive, so it seems like it is not evaporating, or is at least being sucked back in there at a rate equal to or greater than any evaporation.
I asked the mechanic who replaced my O2 sensor for me if he had ever heard of this and he said no. I've had trouble finding mention of this specific issue on the web as well. Wondering if it is possible that the fuel is being sucked back through one or both of these lines to the box, or if there may be a seal or gasket that I need to check for. The cover/box would have been removed to change the plugs about 10,000 miles back.
By accident I found that the small tube on the front right of the airbox goes to the fuel regulator. (I think it does) If the regulator is bad, could that allow fuel to travel through this vacuum line and into the airbox? I found the AC Delco regulator is roughly $70, so not a huge expense, but would like to get an informed opinion or way to test before throwing a part at the problem.
There is no measurable amount of vacuum in the air box. The line from the airbox may go back into the valve cover though. Used to be pcv system would use filtered air from the air cleaner assy to replace the air being drawn out of crankcase by pcv system.
If you clean out the fluid in the air box, how long before it returns? The line going to the fuel regulator has manifold vacuum applied to it. If the diaphragm in the regular is damaged, it may allow fuel into that vacuum line. Should be easy to tell, pull line off both ends and see if any fuel is in there. How sure are you that it is raw fuel? Gasoline tends to evaporate very quickly when heated. Air box gets warm enough to evaporate the fuel.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
