New member from SE Michigan - 2015 Canyon
Hello from SE Michigan. I just recently purchased a 2015 GMC Canyon 4WD, Off Road package (I'll never use).
Love the truck so far, although I should have got the larger bed.
I've had an 09 Avalanche in the past and a Cadillac SRX that I was recently using as a truck.
I'm looking to learn a little more about the Intellelink system to see if I can get some of the functions to work.
What included with the Off road package I'm just curious? Welcome by the way.
Hello and thank you for the welcome. The package was actually the "All Terrain" package which included Off-Road Z71 Suspension, Hill decent, different tires and rims (same size as standard but different), transfer case shield, *Heated Seats* (Required for me), Power seats. (Power seats because when you go off roading you have to have power seats?!?) :) Looking at the package, it was probably a good package but I probably won't take off road much, I do a lot weekend construction work and I did take it down some two-tracks this weekend on a fly-fishing adventure. SO, probably a wise investment. Really, at this point these 2015 Canyons are pretty hard to come by in my area and I had a time constraint with my trade-in. Thanks for the welcome...
Welcome aboard. Post some pics.
Really, this is just a test to see if I can figure out how to post pictures, Isn't it? :)
Ok, I couldn't figure it out from a browser, (there is an icon for inserting a picture in the editor but it asks for a URL) maybe I'll try taptalk.
Ha, not a test. Just have seen a few Colorados around here, but no Canyon's really. I think you can put pics up in your Garage, and then post the link to there in a reply post here.
Welcome to the group, I'm thinking a Colorado will be my next truck. To post pics, I just click on More Reply Options, then Choose Files and go to my picture files and click on picture I want to post.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
