MattDewalt Posted April 4, 2003 Posted April 4, 2003 I just picked up the Champion Truck Plugs for $2.49 each. Should I set the gap at .060 or do you think I should tighten it up a little since I won't be looking to get 100K out of these plugs anyway? Also, these plugs say they are specially coated to eliminate the need for anti-seize. Do you think I should put a little anti-seize on anyway for cheap insurance?
99silveradoz71 Posted April 4, 2003 Posted April 4, 2003 Not sure on the gap, but I'd probably coat them up to be safe.
AirForceAngler Posted April 8, 2003 Posted April 8, 2003 Gap them at the recommended spec. That is what the ignition system was designed to work with. The more gap, the bigger the spark and the cleaner and more efficient it will burn.
