Are '14 & '15 the same?
What's the difference when it comes to the new year with the Silverado 1500's. I'm looking to put parts on my 2015 but when I check to see if they're compatible they are not. If I select that my truck is a 2014, they are! I tried Weathertech floor liners, an exhaust, & more parts.. I'm really looking for a new exhaust, but now I'm stuck.
These both have the new body style, what can really be that much different?
15 doesn't have HD Radio.
That's my only complaint.
Nut and bolt wise I bet it's a carbon copy.
There are minor differences in the infotainment system, other than they are the same. Most sites haven't updated their product compatibility charts. If something say it fits a 2014 it will fit a 2015.
Nothing as far as engine and frame are different. 15s have 4G lte WiFi and also have the available 6.2 with an 8 speed. Everything should cross over, the companies may have not updated the compatible vehicle list yet
I have WeatherTech mats in my 2015. Just say they're for 2014, they fit just fine.
I've got a regular cab, finding parts for that is pretty irritating. But the 2014s are available online, I'm about to order those now
