Time for a tune up
I have a 2011 Sierra with the 5.3 engine. It has 110,000 miles, so I am planning to replace the spark plugs and wires. I know I need to service the transmission sometime as well, but is there anything else I should be looking at or replacing right now? The truck has started to idle a little rough at times in the last few months and even thrown a code that says misfire in cylinder X. I'm hoping new plugs and wire will help that. Any assistance is greatly appreciated.
Plugs and wires will most likely help that. I'd look into a SeaFoam (or similar) treatment. Any signs of oil leaks anywhere? How's the water pump?
Have you ever done your axles? Probably wouldn't hurt to change their fluids.
Transfer case fluid change?
Fuel filter?
Thanks guys. Haven't noticed any oil leaks but I think I did notice a slight leak in either the power steering or water pump last time I changed oil. It just looked a little damp in there. Should probably get that in and looked at. I also want to get the differentials and transfer case serviced before winter. Doubt it's ever been done. I thought I read somewhere that these trucks don't have fuel filters. Is that not correct? Would definitely get that changed as well if I need to. Sure wish I had a lift in my garage. Guess I'll start with plugs and wires and go from there. Advance Auto Parts has 20% off all orders until 7/5. So what better time to do it.
Correct, no servicable fuel filter.
I'd also recommend replacing ALL FLUIDS & adding a can of Sea Foam brand fuel treament now & at every other oil change too. Having the front end alignment checked, tire R&B, & new air filter.
