Leveling Kit
Hello everyone,
I'm new here and this is my first post so excuse me if this topic has been brought up already. I did do some deep searches and didn't seem to come up with a definite answer.
But anyway I have a 2015 silverado CC shortbox, I was planning on leveling it and putting 285/55/r20 when BFG releases that size in the ko2 this September. Well after measuring I found there is only a 1 1/4 inch rake between the front and back, I'm afraid if I do a RC 2" level this would raise the front up to much so when I trailer it will bring the rear down to much. I also have a Leer topper which may be why it seems more level. But also looking through everyone elses post on this topic it seems others have a much greater difference between front and rear.
So would the 2" level without blocks be to much? or can I stuff the 285's under there with stock ride height?
As you can see in the attached picture it sits almost perfectly level with a load. Sorry not the best picture to show this.
Thank you in advance!
Cheap option: buy the RC 2.5" Level kit, install the 2" spacer up front, don't install .5" puck on top of shocks, and install the +1" rear blocks for the rear. This will leave some desired rake.
Or you can call Rough Country and get a +2"block for the rear and install the .5" puck on the front shocks
Option 2: upgrade shocks to bilstein adjustable 5100 or fox adjustable shocks
I suppose doing this, install the front first, measure up and go from there?
Will a 285 look fine under that height?
I installed the RC 2" front lift and it made the rear seem a little to low at times, so I ordered the RC rear block from the 2.5" level kit. I'm pretty happy with it, has a little bit of rake to it.
Do you have picture?
285/55 really isn't much different than stock.
The BFG's will look 10x better than stock tires
So in theory, I could run the 285's stock height with no rubbing. I don't have a huge issue in regards to how it sits now. But I mean if I HAVE TOO...
Go out to your truck now with a tape measure. Measure the gap between tire and wheel well, if you have an .5" gap, you have room.
Now turn your truck on, turn steering wheel all the way to right, get out and measure gap between wheel and tire rod. If you have an .5" gap, you will be fine.
In theory, yes you could run the 285/55 with your stock set-up
Between the tire and the inside of the wheel well towards the motor?
Sorry don't have any pics. It's hard to find a level surface anyway. Since I lifted it, I'm noticing how many surfaces are uneven because I notice how diff the stance looks at times.
After measuring up it seems I have well over an inch of clearance on all sides. Guess the concern would be off the road.
  • 5 weeks later...
ok well yall have really got me in a twist. I just thought I was gonna get some spacers and level the truck. Apparently this can get allot more complicated.
so in short, the spacer is the cheap option, Fox is the expensive best option. whats the really good middle of the road Street option for a 2wd that I just wanna look good and ride nice?
What's so complicated? Rancho quick lifts is an option.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
