Gas Tank POPING
Yes, my '02 did it every time I shut it off. Probably about 30 sec later or so.  There was a discussion about this very topic about a month ago questioning what it was.
its not the tank its the heat shields.  Nothing abnormal
Same problem on a '99 tahoe.  About 3 minutes after driving it sounds like a dent is relieved in a huge coke can :cheers:
More of an annoyance than anything else.  I'll most likely have it looked at when I replace the exhaust.  Until then....THUMP
