Window Trim Clips
Does anyone know the part# for the window trim clips? I snapped a couple while trying to remove window trim for painting. Any help would be greatly appreciated.
If your talking about the trim on the outside at the bottom of the window I think you have to replace the entire trim.
I had one that would not stay in place on the back door and the dealership replace the entire trim. This trim became loose after they replaced the window seal because of a wind noise.
I was afraid of that. Guess I might as well just order some black ones. Thanks for the response!
You can buy the clips separately. My dealer showed me the belt molding, and it was the complete part. I found the part number buried in this forum. The part number for just the clip is 11547339. I ordered 5 from GM Wholesale Direct at $2.26 each
Popped out the old ones with screwdriver, and put in the new ones.Worked great with no problems.
Bert
Is there a proper instruction on removal of these trim pieces?
Bert
Thanks! That's a much cheaper route than replacing the whole belt molding.
I went by a local body shop and he literally twisted it off towards him and didn't break a single clip.
I was thinking of plasti dipping mine black, but would really like to remove and color match.
Bert
I wonder why they replaced the entire part on my truck rather than just the clips. I'm sure that would have been the cheaper repair.
