Houston dealer to change tpms
I am putting 35's on my truck and can't find a dealer that will lower my tpms rating down so my warning message doesn't come on. Anyone know a dealer in the Houston or Beaumont tx area that is willing to change it.
I wonder why they won't help you. All versions of trucks can come with LT tire which would require a change. I am also having 35" tires installed on Monday along with a lift and I have already made an appointment at my local dealership to have the TPMS adjusted. They were more than happy to do it for me they said it is your truck and can put any kind of tires you like.
Finally found one in Baytown willing to do it for me, gonna charge 120
Go ordnance,
What pressure are you going to have them set it at. I'm thinking 40 since I plan to run mine at 45. At least 45 is what I been reading others are running there 35/12.50's at.
Do you just need to have the TPMS sensors relearned when installing new wheels?
If so just buy one of the sensor interrogator tools instead of paying the dealer. That way you can rotate wheels on you own without the dealer.
Haven't made my mind up yet. More than likely around 42 or so. But we will see how it drives when I get my truck back from having everything installed this week.
Go ordnance,
I am confused, the stock warning doesn't come on until around 27psi. Why would you want it raised up so high instead?
Sorry should have stated, I have a 2500
Just wanted to give an update to anyone that ever tries to search what I'm looking for in my area.
Drove to Baytown gmc today after confirming they could lower my tire psi range, after an hour they came out to tell me they can't. Typical car dealership crap.
Anyways still on the hunt to find someone that can. Also they said the newer trucks use global instead of tech 2, not sure if there's any truth to that but what I was told.
Anybody know of someone in the Houston area please let me know. Thanks
Your dealer is telling you correct, as I said in another thread GM has locked the new trucks and vehicles out. They use a new Global laptop based system, GM doesnt allow the dealer to make any changes to the modules other than what the module was programmed with from the factory. You cant go in and use other VIN's either as you could on prev gens.
Pretty much each module is VIN tied, when the dealer updates the module is flashes the newest firmware that GM has on file for that VIN and module.
You can set the TPMS pressure anywhere you want. Need a dealer to do it or a working version of GDS2 ( license expires in 30 days) and an MDI. I did it to my '14 and '15. I run 32 psi for better ride and didn't want the light coming on too soon.
I purchased a tool off Amazon the tpms maxi tool I'll have to see if it does this or not.
Sent from the gym!
I am officially of the opinion that there is zero need to mess with the TPMS monitoring system for larger tires. I run 42 psi in my 35" MT tires and everything on my truck reports as correct. I have no lights or anything. So I have decided that I will not worry about finding a tool for them.
Unfortunately for the 2500 trucks the light comes on at around 60 psi
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
