2015 Tahoe Under-carriage Pics
Noticed oil spots on the driveway after a dealer scheduled oil change. Crawled under the truck to get a look, noticed the filter was wet with oil. Wiped it down then took the truck to the lift the next week. While on the lift I noticed there was a drip of oil on the drain plug and also on the filter. Wasn’t able to determine whether the drip was from a faulty filter gasket or if the drain plug/filter wasn’t torqued correctly. Wiped and tightened everything down, I’ll check again early next week. Since I had the truck 6ft in the air, I took the opportunity to look at the condition of the under-carriage.
Here are a few pics, gave me an idea about the quality of the undercarriage when exposed to my environmental conditions. Other than recent oil stains on some of the other components, everything looked pretty good after driving for 17 months. My daily driving conditions; no rain, snow, ice, or salt. Year round sunlight with an average 60 degree year round temps, daily thick cloud cover off the Pacific causing a marine layer or fog.
post-131535-0-64182100-1438567446_thumb.jpgpost-131535-0-84161700-1438567429_thumb.jpgpost-131535-0-60646500-1438567412_thumb.jpgpost-131535-0-22419500-1438567802_thumb.jpg
Never spray washed the undercarriage and other than wiping down the drain plug and filter, it's basically as is. I have unlimited access to a lift so figured I could give owners a perspective they wouldn't normally see by just looking at the shine from topside. I took about thirty pics and the most I found was this bit of carbon on the tailpipe.
Nice pics of those suspension components! You can really see how different the design is.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
