Anyone have pics after removing the front license plate bracket? If I remove them how big of a hole will it leave in my bumper?
Not sure of the hole size since I live in a no front tag state but if it is pretty bad then you can order a replacement center section of the bumper. GM calls is a "skid plate" for some wierd reason.
Ya I'm gonna take it off next week when I go home. Hopefully it isn't too much of an eye sore.
There is some sticky tape holding the top and two rivets you'll need to drill out at the bottom. The remaining holes are just under 1/4 in.
Edited by loadies
Loadies, did you remove your front plate or did your truck come like that? If so, did it leave any scratches or scuffs?
Edited by GarciaLTZ
Not a close pic, but if you zoom in you can see the two holes. I removed mine a little over a month after getting the truck. Your left behind with some lines of dirt that just wipe away. Looks like it was never there.
Edited by jroyston13
I did it. No marks at all short of the two small holes. Did it as soon as I got the truck home.
so i just attempted to take off the bracket...and wasnt really sure how...which i admit with some embarrassment and laughter considering i leveled the truck and installed the exhaust myself. it seems this pins or whatever the hell they used does not unscrew ?
They are rivets and have to be drilled out. I did it to my friends truck took a whole 10 min, 5 of which was getting the drill haha.
Just removed the front license plate bracket from my new 2016 1500 LS. Three small, barely noticeable holes remain, two on top and one on the bottom. Much better.
Edited by Muley
  • 2 years later...
Sorry to revive this but does anyone know the bit size to drill these rivets out? And do I just drill straight into the center of the rivet? Thanks
    250.6k
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 268 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
