Anyone have pics after removing the front license plate bracket? If I remove them how big of a hole will it leave in my bumper?
Not sure of the hole size since I live in a no front tag state but if it is pretty bad then you can order a replacement center section of the bumper. GM calls is a "skid plate" for some wierd reason.
Ya I'm gonna take it off next week when I go home. Hopefully it isn't too much of an eye sore.
There is some sticky tape holding the top and two rivets you'll need to drill out at the bottom. The remaining holes are just under 1/4 in.
Edited by loadies
Loadies, did you remove your front plate or did your truck come like that? If so, did it leave any scratches or scuffs?
Edited by GarciaLTZ
Not a close pic, but if you zoom in you can see the two holes. I removed mine a little over a month after getting the truck. Your left behind with some lines of dirt that just wipe away. Looks like it was never there.
Edited by jroyston13
I did it. No marks at all short of the two small holes. Did it as soon as I got the truck home.
so i just attempted to take off the bracket...and wasnt really sure how...which i admit with some embarrassment and laughter considering i leveled the truck and installed the exhaust myself. it seems this pins or whatever the hell they used does not unscrew ?
They are rivets and have to be drilled out. I did it to my friends truck took a whole 10 min, 5 of which was getting the drill haha.
Just removed the front license plate bracket from my new 2016 1500 LS. Three small, barely noticeable holes remain, two on top and one on the bottom. Much better.
Edited by Muley
  • 2 years later...
Sorry to revive this but does anyone know the bit size to drill these rivets out? And do I just drill straight into the center of the rivet? Thanks
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
