Will 33/12.50/20 tires rub on 2014 siverado.
Bodine
I have a 2014 silverado and have installed the RC 2" level kit. My truck has the factory 20" inch rims with the 275/55/r20 which is 31.9 inches tall. I was wanting to put a little larger tire and was thinking about a 33/12.50/20 which is 33 inches tall but have concerns about rubbing. Any info would be appreciated.
The issue won't be the 33" tall, that part is fine but I think you'll have rubbing due to the width of the tires. I'm going to be going with a 275/60R20 myself whenever I get the level done to my truck. It won't be as wide as the ones you want but it will still get you the 33" tall.
You will be fine with a 33/12.5r20 if you use the stock wheels. The stock wheels have a +27 offset and provide the best platform for larger tires.
Not the exact same but I run a 35/12.5r20 with my stock wheels and the width is perfect.
Yes my father in law has this setup and they run a little at full lock.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
