Average labor cost/time for lift kit?
Shtoy
Good afternoon everyone,
I have been getting some quotes this week on getting a BDS, or an RC lift kit on my '15 Sierra. I'm looking at 3.5" all the way up to 6". I've gotten labor hour quotes for 9 hours @ $50/hour for the 3.5" lift and all the way up to 14 hours at $50 for the 5" and 6". Are these numbers accurate? They seem rather high, the cost per hour doesn't but the number of hours does.
They also charge $100 for the alignment and balance. And a few other nickles and dimes.
Total cost for the RC 3.5" lift and a new set of Cooper S/T MAXX 33's would be $2545 out the door.
Total cost for the RC 5" lift without tires would be $2054.
Are these estimates in the realistic ballpark?
Thanks a lot for your time!
Austin
Its not a bad job.
My 11 y/o son and I did my 6 inch lift in 6 hours.
That was right after I started receiving treatment for a brain tumor, so I wasn't at 100%.
That's another avenue I could try to take...
I would have all the tools necessary with the exception of a coil spring compressor. Is this a life saver?
Putting all that aside, how are you doing today? I really hope you're doing much much better...
Cost of install sounds right. I paid $800 for mine. They likely have more than one person doing install so 14 hours is between 2 ppl, install shouldn't take longer than 8 hours for a 6". Shop took around 6-7 hours to install mine but I had to get an alignment done elsewhere
Thanks a lot Mike, I didn't even think of splitting the hours between 2 people. That makes complete sense. I would like to tackle it by myself, but I really don't have the time to do it as I am moving next week. I would like to get it done though, so I may be bringing her in to the shop. Would you recommend the tires you put on yours or could you offer any suggestions over the cooper s/t maxx?
As far as lift, are you happy with yours and do you happen to have any regrets in hindsight?
Thanks a lot!
Austin
Thanks a lot!
Austin
I'm really happy with mine. Front end is great, the rear is stiff as hell from the anti axle wrap blocks, but thats to expect with any block of its nature. If you can get a skinnier (not as wide) block that is the appropriate height and trac bars then to my knowledge that should help your ride a lot since the rear springs won't be so tight.
other than the rear end I'm happy, but I'm already ready to jump up to the RCX 7.5" lift with a 1.5" BL so I can try to run some 37s lol. But for now, I'm good cause I can still get into most parking garages in town where I go to school.
As far as tires go, I love mine. I have never seen the S/T maxx in person so I can't really judge on them much, but the research I did and several vendors that sell both mine and S/T Maxx tires say they are extremely similar. I say the biggest differences are tread pattern and sidewall. I like how aggressive my sidewalls are compared to the S/T and my tread looks more aggressive. But its still insanely quiet. Im not saying its silent by any means, but when you look at these tires youd think they would scream on the highway but they aren't bad. I actually heard a few other trucks with Trail grapplers drive by me on my way to school and I heard them over my radio with the windows up.
That's good info on the noise...I hadn't factored that in too much. I am really drooling over the Cooper STT Pro tires also. I may end up with those, I just haven't heard much about them.
7.5".....Wow. Are you NOT wanting to get into the parking garages? :driving:
Lol. I'm just wanting bigger. Tired of going to truck meets and seeing guys with 9" lifts and 37s and I'm just chilling with a 6" and 35s [emoji20]
Truth be told, I don't care much about parking garages, some are great but more often than not they are just way too crowded and leave just enough room for you to be able to pull into a spot and not enough to open a door to get out. Anything with driving here in Louisiana sucks. Or at least where I am.
100.00 per hour BDS states that their lift takes 8 hours. So the off road shop I used charged me 800.00 it took them longer than that but didn't matter as that is what was recommended.
Thanks for the info. I think I'll just go ahead and go for it. I'm still debating on which lift to go with. We are talking well over $1200 between a 3.5" and a 5 to 7" lift. If I keep it at 5, I'm having trouble justifying $1200 for 1.5" extra lift...
I think a better question is what size tires you plan to run and want to run. That was the biggest thing that kept me from a 4" cause I either wanted just a simple 4" or go big. But wanted 35s on a 20x9 0 offset rim so I had to go 6" minimum
Honestly I really like the look of 33's. I don't want the wheels to be sticking out more than an inch or so from the body. I do not like that look much. There seems to be a sweet spot with 33's....
If you want to stay at 33" then I wouldn't go any higher than a 5" personally. But I'm a fan of a more stuffed wheel than a huge wheel well gap
I definitely agree with that statement. It looks like from his profile he has a 2.5" level as well as a 2" rear lift.
Would the rear lift be a body lift?
Also, I think 295/55R20 would be the perfect size for what I would want
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
