Well, pretty sure I am joining the Ford team.
LaserBlueZ71
Finally found a Super Duty to my liking, and pretty sure I am going to trade in my 2011 Silverado 1500. Originally I wanted a diesel, but the more I researched it, I think the gas engine is the way to go for me. My commute is short, 10 miles, and I do not tow or even work my trucks hard. With all the insanely expensive repairs on the modern diesels, I would rather put up with the lost MPG and power and have reliability and peace of mind.
Now, can anyone comment on these trucks? Am I making a good move by going from a half ton 1500 into a lifted F-250 as a daily driver? Again, this isn't a work truck, I just drive pickups because that is what I like to drive.
What I am looking at is:
2013 Ford F-250 Super Duty
6.2L gas V8
Lariat edition - full load, heated leather seats, sunroof, navigation, rear view camera, the whole deal.
BDS lift (not sure of height, either 4 or 6)
20'' BMF wheels on 35 inch Hankook A/T's
40,000 KM.
Let me hear your thoughts!
Well, since a 1500 is already overkill for my needs, I don't know what you're looking for to gain in a HD if you don't haul/tow much.
But that's your business.
And, I think you already know that, the fuel economy will take a huge hit with a lifted HD gasser compared to a 1500.
Just my 2 cents.
so long
j-ten-ner
Ford 6.2s are gas hogs on a good day. Gas is cheap now but you know that won't last. Modern HD trucks are nice, but I'm not sure I'd want to DD one.
That move would be one of the worst mistakes you made. For me I would never buy a 2nd hand lifted truck and that truck will take you to the cleaners on fuel cost. The truck might look cool and nice but it will wear off in a few months and you will be thinking "why in the hell did I do that".
Going from a 1500 series pickup to a 2500HD from any manufacturer makes absolutely no sense at all if you don't need that truck for a specific purpose. If you don't tow heavy/haul heavy, why not just stick with you current truck? Are you having any issues with it that you are willing to get into a truck that's going to cost you more money over time?
You should also know the information about the truck before you buy it. Buying a vehicle and not knowing how it's equipped doesn't make sense either. Find out how much lift it actually has, and how it's lifted. You also should know the gear ratio because that's going to affect the F250's already poor MPG with the added stress of the lift/tires/wheels.
It seems you are buying based on appearance alone. It would be much cheaper to lift your current truck and stick with it. Your fuel cost is going to be significantly higher than it is now. The Ford 6.2L engine in the HD's is very thirsty and it's only going to be worse with the lift and heavier tires/wheels.
It's your money so do as you please. If you want reliability and piece of mind, stick with your Silverado. If you want to double your fuel cost, increase the amount of money you will spend when it comes time to replace the tires, and look cool in a lifted pickup go ahead and buy that F250.
Good luck with it, hope everything works out for you.
I have been thinking about this for days and I think you guys are right.
I have come to my senses and realized I would be buying on looks alone. My Silverado has not given me an ounce of trouble, averages 20 MPG for my city driving, and rides like a dream. Even if I lift my Silverado and put on 33 inch tires, I will STILL get better fuel economy than a STOCK 6.2 F250, nevermind one lifted with 35's. Not to mention, I am almost payment free and my 2011 only has 46,000 KM on it, and I am the original owner. I know everything my truck has gone through.
The Silverado stays!
For me, the look of a truck is a big factor.
But also the overall economy (fuel, maintenance, payments etc.).
Even lifted or lowered trucks catch my eye when it's done proper and everything "flows". Just slapping on big wheels and tires doesn't cut it for me.
The temptation to look at newer or bigger trucks applies to me too.
After all, we're truck guys.
so long
j-ten-ner
That's just it. If I modify my own truck, I do all the work myself and I choose all the parts myself, it's a pride thing, and it will be exactly what I want.
Since I just drive a truck because I like it, and do not need it, a half ton is already more than I need. Truthfully speaking if I was to replace this truck, what I really should be looking at is a new Sierra half ton. My truck has given me no problems at all (knock on wood) and gets excellent fuel economy for what it is. Why get rid of a vehicle that has never let me down and runs well?
Now that I think about it, I am so glad I didn't make an impulse decision and buy that super duty!
:thumbs:
You have made a wise choice.
Yeah I think you're spot on, stick with a 1500, stick with a GM the other trucks just don't do it for me. I love my '14 Sierra SLE, it's the best vehicle I've ever owned.
I am coming from ford. I just bought a 15 silverado about a month ago. They make good trucks don't get me wrong, but they are gas hogs. I had 5.4 tritons in both of my trucks and averaged 10mpg. At my work we have a f450 dump truck with a 6.2 and the truck which is severely under powered and it gets 4mpg. If you don't have a need for a HD, I wouldn't suggest buying one. It is just an overall waste of money.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,100 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
